I was trying to do some basic calculations for the cooling cycle. Multiplication/addition/division/etc. with some variables I set. Turned off computer and when I went back to continue I get this error:
The file type is not supported.
Log file is located at: c:\ProgramData\PTC\Mathcad Prime\Logs\Mathcad Prime_Exception_20150407_164625.log
I was wondering if there is any way to get back at the file without having to start over from the beginning. Attached is the mathcad file I was attempting to open and the Log file referenced in the error.
Nevermind, just started over.
I've moved this discussion into our Mathcad community in case there is any follow up and you need some additional advise from our members here.
