I actually want to plot an if function for a certain range of numbers. I have tried to generate the values via a loop, but it just won't run.
I actually want to plot the if function for values between 0 and 1.
I'm sure it's quite simple, but somehow I'm stuck.
Best regards and many thanks
It is recommended to define a function in Prime for calculating the kR values and then use this for plotting or generating vectors.
Even if you seem to have already found a solution for yourself, the attached file may still contain some useful information.
Translated by the moderation using Google Translate
Es empfiehlt sich, auch in Prime eine Funktion für die Berecnung der kR-Werte zu definieren und diese dann zum Pllotten oder für die Erzeugung von Vektoren zu verwenden.
Auch wenn du bereits selbst eine Lösung für dich gefunden zu haben scheinst, enthält die beigefügte Datei vielleicht noch die eine oder andere nützliche Information.
@MS_12003747 wrote:
I managed to do it myself 🙂
Very fine!
The file I attached earlier might still contain some useful information for you.
Your function k(x) would also be perfectly OK - the error only occurs because you are trying to evaluate it immediately after the definition (the equals sign at the end). Of course, Prime doesn't know what value it should use for the formal parameter x 😉
We don't have 10.0 at the UniBw yet. I hope we get it soon. So I can't open the file.
But thank you very much anyway!
Wir haben an der UniBw noch kein 10.0. Ich hoffe wir bekommen es jetzt schnell. Ich kann die Datei daher nicht öffnen.
Aber trotzdem vielen Dank!
You should always indicate if you are not using the latest Prime version. Unfortunately, PTC has not provided a way to save a file in an older format, so I am unfortunately no longer able to make it available in an older format.
As a small remedy, I have attached a PDF printout of the file, which should also show all the information.
Du solltest immer angeben, wenn du nicht.aktuelle Prime Version verwendest. Da PTC in seiner Gier leider keine Möglichkeit vorgesehen hat, eine Datei auch in einem älteren Format speichern zu können, kann ich sie bedauerlicherweise nicht mehr in einem älteren Format zur Verfügung stellen.
Als kleine Abhilfe im Anhang ein PDF-Ausdruck der Datei, der auch alles an Information zeigen sollte.
Awesome! Thank you very much!
Mega! Vielen Dank!
