Attached find a worksheet with three questions about usage of °C in Prime.
Instead of using "delta°C" I could use "K", which isn't any better, though.
I know this problem and do so:
Thanks.
As Delta°C=1K and 0°C=273.15K thats pretty much the same which I do. So it seems to be that uncomfortable to do.
At least assigning the expression to a variable with same name and different style helps not to clutter the limited space in the graph.
Would be fine to have units at the markers, too.
This problem in Mathcad 15:
Yes, Prime is doing graphs better with units, but then still not perfect 😉
