Raeding in metadata from Windows folders
Raiko
I have the tedious task to count folders and subfolders in order to determine a certain count. Does anybody have a sheet, preferably in MC15, that can count folders and access the date of creation of said folder?
Thanks in advance
Raiko
1 ACCEPTED SOLUTION
A little addition to help. I have added in a component from Richards collection which will allow you to select where folder and the relative path will be returned.
8 REPLIES 8
MikeArmstrong
(To:Raiko)
Would something like this work for the first part?
Raiko
(To:MikeArmstrong)
Hello Mike,
thanks for responding. Can you give me an instruction on how to use your function?
Raiko
MikeArmstrong
(To:Raiko)
Hi Raiko,
The fuction was actually posted a while back by Philip Oakley. However, you will need to change the path "C:\YOUR PATH" to point at the folder were you want to count the files. Then you will be able to progress from there.
Raiko
(To:MikeArmstrong)
Mike, that much I understood. my problem however, is to count folders and not files. Therefore I can't work with extensions.
Any idea how to adapt the worksheet?
MikeArmstrong
(To:Raiko)
Sorry Raiko, try the second scripted object in the attached worksheet.
Raiko
(To:MikeArmstrong)
Thank you Mike. That did the trick
Raiko
MikeArmstrong
(To:Raiko)
No problem. I can't take the credit for developing them, just reciting them
I can't find a component which indicates when a folder is created, but there is a component which calls up when a file is created if that will help.
