Read input from pdf or text note
YA_10963798
I need to input data from Notepad . Can mathcad do that ? using ReadText function or there is another way to do it ?
This is the data I need to input , I couldn't attach the note file because the file type is not supported , so I attached as pdf
LucMeekes
(To:YA_10963798)
Yes, Prime can do that.
Look up the function READTEXT in the help of Prime.
Here's an example, based off the pdf file (and starting with the line containing #EOH= ) :
Results in:
etc.
LucMeekes
(To:YA_10963798)
Results in:
etc.
YA_10963798
(To:LucMeekes)
what does '' delimited'' do?
And  should I write my file name instead of '' File'' ?
As Luc said, look up READTEXT in Help: https://support.ptc.com/help/mathcad/r10.0/en/#page/PTC_Mathcad_Help/text_files.html
You'd write your file name in quotes.
Delimited says how the data is structured in the file (how Mathcad is supposed to know when a new column begins and the old one ends). In the case of his example, a space (" ") is the delimiter.
I manage the Creo and PTC Mathcad YouTube channels for PTC, as well as all PTC Mathcad marketing in general.
