Referenced Mathcad 15 sheet won't 'import' array
Hi, Can anyone out there help? I have a fairly basic calculation sheet, in which I want to use results from another worksheet. I have done the insert reference, saved, saved again, hit F9, hit it again, opened, closed, re-opened, re-closed etc, but simply cannot get the recipient worksheet to find the array results that are generated in the referenced sheet. It will happily find 'simpler' results (single numbers, single column arrays), but will not find the larger 2 dimension arrays. The arrays I admit are large, 130 x 500, but that is what we use expensive software for isn't it?
