I can find and replace 2 for example to space in Mathcad 15 (Ctrl+h) but cannot do it in Prime ![]()
Is it a bug?
It won't let you do that in a math region, but it will in a text region, so I assume that's by design. However, type variable2 somewhere in the worksheet and search for 2. You will notice that all of "variable2" is highlighted, not just the 2 at the end. Sure enough, if you type 3 in the replace box and do the replace, you get "3", rather than "variable3". That is certainly a bug.
Thanks, Richard!
I think Mathcad 15 has bug too.
I have a number 222 and would like to change all 2 to 3 for example 222 -> 333.
Try please with Ctrl+H. We can change only first 2 - 222 -> 322
Yes, you are right.
