Resolve dependent variables
BPP
8-Gravel
8-Gravel
Hi everybody
I have a system of equations with three variables that depend on each other and that are solved by iteration. What I am trying to do is to leave this system of equations in function to the variables ds, Ds and Dliq.
To better understand what I want, I have attached an example of what I want to do.
In advance thanks for the help.
(To:BPP)
Terrys example shows what you basically have to do to turn a solve block into a function of some arguments.
But the approach will fail in your example because the result of the solve block is a vector with elements of different dimensions (2x dimensionless and 1x speed). This is something Mathcad cannot deal with.
So you would have to correct for this additionally - either make v.s dimensionless or make the other two with dimension speed.
See the attached of some ways how to accomplish that.
-MFra-
(To:BPP)
terryhendicott
(To:BPP)
You can define a function to equal the "Find" statement.  This is called parameterizing the solve block.
Here is an example.  You can do the same in your instance.
Cheers
Terry
(To:BPP)
BPP
8-Gravel
8-Gravel
(To:Werner_E)
Thank you very much to both
