In Mathcad 15 and MP1 the result would have as many digits as you want. Can I get a result with only two digits which has not been rounded to the next up or lower number?
If you mean "can you set the result formatting so there is no rounding", the answer is no. You could use the Trunc function to truncate the number though.
