Dear All,
I am trying to write a program to return the only KP values when F is greater than 0.
Again its not really clear what exactly you expect as result and giving one or two examples would have helped.
In the following approach I assumed that you want a vector with the values of KP but replace the original value if the value in F at the corresponding position is negative.
Here is a short approach using vectorization
We can use a table built with augment to check the results
And here is a more "natural" approach with a function using a for loop
You can replace the 0m by NaN or whatever may be appropriate.
We can check if both ways return the same result
Using the if-function we can write it less space consuming
One may think that we could simply vectorize that if-function
but this does not work
because Prime does not allow to vectorize comparison operators like the < directly, but we are allowed to vectorize a function which uses the comparison:
Prime 9 worksheet attached
I would like to add also a function to filter to return only the KP where F > 0 and another matrix showing the only F > 0 values.
Examples always would be welcome to clarify what exactly is needed.
A I understood it now you want the values in both vectors removed when F is zero or negative so only the positive values in F remain and also the corresponding values in KP?
Could be done in many ways, one is shown here
