Rnd in the cycle of Mathcad Prime - an error?
ValeryOchkov
I see an error by the using rnd function in the cycle of Mathcad Prime - see attach. In Mathcad 15 all is OK!
See the picture and Mathcad 12 and Prime 2.0 files.
5 REPLIES 5
Your picture (for Mathcad Prime) has the word Dice twice rather than Dice1 and Dice2 However, even correcting this the result you show still stands.
If you replace 1+floor(rnd(6)) by ceil(rnd(6)) you get essentially the same result as for M15, suggesting the problem is with the floor function rather than with rnd.
Alan
Tahks, Alan!
You see the error too!
1+floor(rnd(6))
ceil(rnd(6))
works correct too.
But
1+floor(rnd(6))
1+floor(rnd(6))
not.
I have sent the message with this error to Mona!
Here are two versions that use floor(rnd(6)) twice and do work! The second example suggests things go astray when adding 1 to the random integers!!!!
Alan
Uh-oh! Weirder still!!
Alan
It was a preprogram of this program - http://communities.ptc.com/message/184194
See too ne picture:
