Save Window Pops up
Joeboy
Save Window Pops up
I have some Mathcad files where I have set the autosave to say, 2 min. So every 2 minutes this window pops up with the name of the file, doesn't do it for all files just some (probably a glitch in an earlier Mathcad version). This is irritating and can cause the system to lock up if it occurs at just the right time. I am using Mathcad 15.
Has anyone experienced this problem ?
If so is there a fix for it ?
I have attached file that exhibits the behavior I'm talking about on my computer.
22 REPLIES 22
I was having exactly the same problem yesterday and ended up turning it off. Do you really need to have it auto saving every 2 minutes? Why not increase it?
Mike
Mike,
Could you provide a screenshot of this pop-up window?
Unfortunately I cannot replicate the issue. I was working from the server in work and thought that might have been the issue, but I'm not recieving the message now.
Mike
Joeboy
(To:Joeboy)
Yes, but why does this occur on some files not others and is there a fix for it ?
Very strange. I have just set the Autosave on a new document and I don't see the popup box. Is actually might be a bug. Try saving the file as a separate name and see if the error occurs.
Mike
Joeboy
(To:MikeArmstrong)
Tried that, if it happens changing the doc name does not help
Joeboy
(To:Joeboy)
This does not happen for all files just those that were created during a certain period of time, several years ago with version 11 or 12, don't remember.
I think your on to something there because I was updating an old Mathcad document.
Mike
Joeboy
(To:MikeArmstrong)
I tried bringing up the issue with PTC but they won't talk to anyone that is not paying them money, even to learn of a problem
Good job Vladimir has done it for you :-).
Mike
MikeArmstrong wrote:
Very strange. I have just set the Autosave on a new document and I don't see the popup box...
But it re-saved the file (look at the time data in properties of the file)?
Yes.
Mike
VladimirN
(To:Joeboy)
DixieGriffin wrote:
...I am using Mathcad 15...
What a service release (F000, M005, M010)?
Joeboy
(To:VladimirN)
Mathcad 15 M010
Fred_Kohlhepp
23-Emerald I
(To:Joeboy)
Might this behavior be tied to the file name? Your attached file had a name that I would have thought might trip the operating system, C@C and the file length.
It was also happening to me and my filename contained only letters.
Mike
Joeboy
(To:MikeArmstrong)
I have many files with C@C as part of file name
I didn't think it was the filename, maybe a compatability issue with older worksheets.
Mike
VladimirN
(To:Joeboy)
DixieGriffin wrote:
...So every 2 minutes this window pops up with the name of the file..
Can you provide a screenshot of this window? Because I have set Autosave (2 min) for your file and there are no pop-ups windows.
Joeboy
(To:VladimirN)
I opened the same file you have and (wouldn't you know it) the popup does not now appear. Perhaps it is because I saved the file, I don't know. In any case it will happen again and when it does I will send a screen shot.
VladimirN
(To:Joeboy)
Ok.
Joeboy
(To:VladimirN)
here is the popup I'm getting, the file producing it is attached
