I use the save function a lot. However I find that on many files I get a pop up showing a description of the file being saved each time it is saved. So if I set save to 5 minutes I get this pop up every 5 minutes. If the pop up occurs at the instant I am working on a file that file may be damaged. I reported this several times it was ignored. Has anyone else had this problem and if so is there a fix for it?
I guess you are talking about Mathcad 15 and its "autosave" feature.
I never got a pop when saving a file in Mathcad 15 - not when saving the file manually (e.g. via Ctrl-S), nor when I have autosave on.
Are you sure that the popup stems from Mathcad or can you post a screenshot?
I will post it next time I get one
