Save function not working properly ?
Joeboy
I use the save function a lot.  However I find that on many files I get a pop up showing a description of the file being saved each time it is saved.  So if I set save to 5 minutes I get this pop up every 5 minutes.  If the pop up occurs at the instant I am working on a file that file may be damaged.  I reported this several times it was ignored.  Has anyone else had this problem and if so is there a fix for it?
(To:Joeboy)
I guess you are talking about Mathcad 15 and its "autosave" feature.
I never got a pop when saving a file in Mathcad 15 - not when saving the file manually (e.g. via Ctrl-S), nor when I have autosave on.
Are you sure that the popup stems from Mathcad or can you post a screenshot?
Joeboy
(To:Werner_E)
I will post it next time I get one
