Scale in 2d plot
ebelmonte
Scale in 2d plot
Hello all,
I have two questions regarding the use of the 2d interpolation function:
  1. As you can see in the attached file, I cannot display the x-axis in the right way.
  2. How can I use the fit function for the get the results from an input array?
Thank.you very much!
Enrico
A standard 3D plot of a 2D array uses array indices for X and Y  axis.  To plot the FIT function, use "CreateMesh"
8 REPLIES 8
-MFra-
(To:ebelmonte)
Hi Enrico Belmonte,
You have simply to remake the 3d plot, as I have done:
Saluti
FM
Hello FM,
Thank-you for your reply.
However on the x-axis I get vales between 0 and 10 and not between 1E4 and 2E4.
What about the second question?
Thank-you very much!
Enrico
-MFra-
(To:ebelmonte)
It seems to me that it's okay!?!?
Furhermore, you can use the following program for a more accurate plot, but with the condition that the input matrix be a square one:
Example of "fitfield" use, plotting the function f(x,y)=sin(x)*sin(y)/(xy)
(To:-MFra-)
No, the scale in x- and y-direction is not as requested.
(To:ebelmonte)
Guess its easier than you think:
Using the first method (directly plotting the fit function) you would have to provide the ranges for x and y and also the number of grid in the "3D-Plot Format" window in the "Quickplot" tab.
So generally using Createmesh provides more flexibility and usually is the preferred method.
  1. How can I use the fit function for the get the results from an input array?
Input array? not sure what you want to achieve.
Dear Mr. Exinger,
I would like to calculate the fitting function using two input arrays instead of computing the values of the fitting function for a couple of values only.
Enrico
(To:ebelmonte)
Guess you need to use vectorization:
