Sensitivity Analysis in MathCAD
AshehadAl
Perhaps, this sounds complicated but I am wondering if there is any easier way of doing sensitivity analysis of the parameters in MathCAD. i.e. Suppose you have a range of values of different parameters and each time a set of parameters are called in MathCAD, root function is then used to evaluate. Can the range of all parameters be in excel file, with the parameter defined in excel file, MathCAD reads every row from excel and goes to the root function and asks for the endpoints to be changed. Then the answer is stored in the same or another excel file.
Ashehad
I think the answer to your question is yes, but it would be much clearer if you uploaded a worksheet with an example, and maybe an Excel worksheet holding the data.
Mike
Uploaded on behalf of @AshehadAl
I can't open this file: "AshehadAl_Example.xls"
Resaved file. Contents may have been altered from the original state.
Hello!
Perhaps the following materials will help ("Sensitivity Analysis Using Mathcad"):
Topic on PlanetPTC Community: http://communities.ptc.com/message/83020
APPLYING MATHCAD TO THE HIGHWAY CAPACITY MANUAL: CHAPTER 7 SENSITIVITY ANALYSIS
