Showing a graph on Pro/E drawing
AntonioVillanue
Is it possible to create a graph on a Pro/E drawing? Not as an image, I can do that from Excel. Maybe something from MathCAD? I guess if I can get a DXf of the graph, that would work. Any know a good method.
You can "print" it to a postscript file, then use a small utility called "pstoedit". Basically it has an option to convert a postscript file to a dxf file. You can google it or go here:
http://www.helga-glunz.homepage.t-online.de/pstoedit/
