Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Your message : http://collab.mathsoft.com/~Mathcad2000/read?126552,16 I noticed the same failure about W. This project is now like frozen with nothing new for public interest. Maximize does not fail, though you reported 0.518 (from recollection) and Maximize reports 0.516. The complete Given/Find was added at the time.
