Solve Block Error
Ravi_05
3-Newcomer
Solve Block Error
I am new to this Mathcad prime earlier I use Mathcad 15, I am trying to solve this equation in the Mathcad prime, but I am not getting the value, I also searched on the net but didn't find any proper solution.
Please help me to solve this issue.
To find the vale of the (an)
The file is attached
(To:Ravi_05)
While the root-function as suggested by Fred is more compact and may be preferable in this case, I just wanted to point out the two errors you made:
1) Your guess value is missing a length unit
2) You had a typo in "find(an)" - there was an superfluous dot after the "n". Probably because you were used from MC15 to get the literal subscript by typing just a dot instead oft he more elaborate "Ctrl -".
P.S.: You sure know that "Given" is not recognized any more by Prime as being the start of a block and so this part is obsolete:
I only have Prime Express, so I can't check the operation of your solve block.  I can use the "root" function to solve your problem:
And I think if we assign units and use "Find" instead of "find", the solve block should work too.  Attached
Thankyou sir 🙂
(To:Ravi_05)
Ravi_05
3-Newcomer
(To:Werner_E)
Thanks for let me know about the errors I have done.🙂
