Solve block
JM_10241707
8-Gravel
Solve block
I am trying to get the answers using the minerr in solveblock but somehow minerr seems to be doing nothing. Can somebody provide any insights on this what I am doing wrong ?
(To:JM_10241707)
The guesses you provide yield a non-real result.
Try to choose guess values which make the expression you want to be zero a real value.
Or, if appropriate, you may use the absolute value:
Furthermore I would suggest that you define a function for the constraint
and use this function in the solve block and to check the result:
Of course you cannot expect a unique solution - you provide just one single equation but have eight variables to jiggle around!
(To:JM_10241707)
(To:Werner_E)
Your equation is VERY sensitive wrt small changes in the input values.
I played around a bit, formulated three constraints, demanding the Real part, the Imaginary part and also the absolute value to be zero and "weighted" these constraints by multiplying with various powers of 10.
Here a result with a real valued function value pretty close to zero:
Prime 10 sheet attached
Hello @JM_10241707
It looks like you have some responses from our community champion. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
