ttokoro
Mar 20, 2020 9:53 AM UTC
Solve diagonal resistance of resistor 3D mesh.
Diagonal resistance of regular polyhedron. R(4)=1/2, R(6)=5/6. How about R(8), R(12) and R(20)?
ttokoro
ttokoroAnswer
Mar 24, 2020 9:25 AM UTC
t.t.
Mar 20, 2020 5:22 PM UTC
Mar 22, 2020 3:13 PM UTC
A simplification of the network topology allows you to easily apply Thevenin's theorem:
ttokoro
ttokoro21-Topaz IAuthorAnswer
t.t.
ttokoro
Sep 2, 2020 8:10 AM UTC
image.pngThe diagonal resistance of resistor 3D mesh is 5/6 ohm.
How about 1*2 3D Mesh?
Each branch resister is 1 ohm.
t.t.
ttokoro
Sep 8, 2020 8:14 AM UTC
t.t.
ttokoro
Sep 9, 2020 3:53 AM UTC
i=2:    1*1*1
i=3:    1*1*2
i=4:    1*1*3....
t.t.
ttokoro
Jul 10, 2021 11:25 PM UTC
t.t.
ttokoro
Jul 31, 2021 12:54 PM UTC
t.t.
18-Opal
Feb 21, 2022 1:51 AM UTC
I don't know why every body went to town on this. You already gave the V and I  so R = 5/6 ohms.
But as an academic exercise - as others have given but more colourful pictures are here:
https://www.rfcafe.com/miscellany/factoids/resistor-cube-equivalent-resistance-kirts-cogitations-256.htm
ttokoro
Feb 21, 2022 3:50 AM UTC
This is not solving 3D 1*1*1 grid resistor mesh only. Using Mathcad or other mathematical programs we can calculate more interesting resistor grid problems.
1/3+1/6+1/3 can not use if the grid is 1*1*2. I post many unique resistor grid problems here.  This time 60 node soccer ball resistor grid result is shown. Please try to solve it because I can not find any answer in WWW sites. Without using Math software, we can not solve such as R1-2 of resistor ball.
1*1*2        1*1*1
t.t.
18-Opal
Feb 21, 2022 11:15 AM UTC
Mar 15, 2023 3:57 PM UTC
What do you think of my solution?  Maybe I took the wrong node as a reference point?
2RBridges 0.jpg2RBridges 1.jpg2RBridges 2.jpg2RBridges 3.jpg2RBridges 4.jpg2RBridges 5.jpg2RBridges 6.jpg2RBridges 7.jpg2RBridges 5.jpg2RBridges 9.jpg2RBridges 10.jpg
ttokoro
Mar 15, 2023 11:35 PM UTC
I will check your circuit. Please upload your Mathcad worksheet. I use Prime 9 to solve it.
I view your post and I understand this is 3D cube circuit with 12 one ohms to find the equivalent resistance of diagonal nodes. Node method is used to solve the circuit. I think this is the best method to solve the resistance.
t.t.
Mar 16, 2023 8:37 AM UTC
Undoubtedly, I made some mistakes. As for the theory, I was inspired by some texts including: "Linesr and non linear circuits" by L. O. Chua, C. A. Desoer, E. S. Kuh, for the construction of the TABLEAU matrix. You can find my worksheet attached.
Greetings
ttokoro
Apr 19, 2025 3:54 AM UTC
3.4.5 ohms cube.
1 ohm circuit by 1 ohms. Each 1 ohm has different current when apply 1A for 1 and 13 nodes.
t.t.
ttokoro
Dec 20, 2025 11:08 AM UTC
Diagonal resistances of n-D cubes. AI only knows 3D and 4D ones.
t.t.
ttokoro
Dec 25, 2025 6:43 AM UTC
t.t.
ttokoro
Jan 24, 2026 10:00 AM UTC
Source and Image Credits: Ellenberg, J., Libedinsky, N., Plaza, D., Simental, J., & Williamson, G. (2026). Bruhat intervals that are large hypercubes.
New hyper cube circuit 2026.
t.t.
ttokoro
Jan 28, 2026 9:59 AM UTC
t.t.
ttokoro
Feb 21, 2026 12:01 AM UTC
Diagonal resistance of Galileo's 12-20 cube cauldron at the Milan Olympics.
t.t.
