Solve...
kenan2
Solve...
Hi
Somebody there can tell me how I can get the angle into a number not in a matrix ?
5 REPLIES 5
(To:kenan2)
-MFra-
(To:kenan2)
The angles that satisfy the equation are three! So what do you want?
(To:-MFra-)
No! Not just three!  Infinite!
I added the reply above to draw attention to the fact that there is a double post and the question is already answered - just follow the link above!
As I already had written that there is an infinite number of angles satisfying the equation. Prime is just showing the three in a predefined range (-pi/2; pi/2]. We could change that range using the assume command.
I also already suggested assigning the result to a variable and accessing the individual elements along with some other ways to get single numeric values.
-MFra-
(To:Werner_E)
Thanks Werner for the clarification. However, perhaps "kenan2" did not know how to highlight the individual elements of the vector, in this case the individual angles .... so I have calculated three roots as an example ....
(To:-MFra-)
Thats most likely, I guess. As seen in the other thread he seems to be struggling with math generally and with the solution of goniometric equations in particular.
