Solving ODE
rmikołajczyk
8-Gravel
Solving ODE
Hello.
I need to solve many simple ODEs and I need coefficients of each power of x. I don't know how to do it or whether it is possible in this software (PTC MathCAD Prime 3.1). Please help. I show example below.
vlehner
(To:rmikołajczyk)
Hi Rafal,
look at the Attachement, hope it helps you.
Regards, Volker
Volker
6 REPLIES 6
You do not have ODE's but a set of 4 equations and 4 unknowns:
Maple
Thanks for answer
But it isn't what I expected. I must determine (define) every single variable separately and finally I'll get the function. Above it is simple example, where every equation give one coeff. I can do it myself on paper faster. I would like to determine boundary value problem [where each of the problems are different and they are related to w-w''' ] and get the shape of function. Is this possible even? Is it possible?
vlehner
(To:rmikołajczyk)
Hi Rafal,
Regards, Volker
Volker
Thanks to everybody for answers
It seems that Volker Lehner‌ solved my problem. Thank you!
