Solving an integral with limits being a vector
bçakır
I'm trying to solve an equation that holds an integral in it. In that equation there are several constants and I would like to solve this for different values of that constants. However, it gives an error as "this value must be real". I've tried to sum up my problem if it is not clear i will glad to explain and get some help.
Mathcad file is attached.
Burak
RichardJ
(To:bçakır)
Turn the solve block into a function of the variables you wish to change, and then call the function with the vectorize operator.
RichardJ
(To:bçakır)
Thank you, it is so clear:)
