I am having a heck of a time trying to get my subscrits to work out. I have looked all around and am just frustrating myself, so I figure I'll give this a try. I am trying to do iterations, so what I would like is something that is y(subscribt j+1) as a function of x. So it would look like y.j+1(x). Where just j+1 is subscripted. If that makes sense. I can't get it to do anything but multiply. Please help, thanks
Ok, so I think my problem is much deeper than just subscripts. I have a new question. I have a problem with iterations, but it is of functions. In other words, I want to take iterations of a function of x. But when I try it says a name is required. Can I take iterations of a function? Do I need to do something like a float, I have no idea
Please post a worksheet. A problem like this is near impossible to solve without one.
Mike
Do you mean something like the attached?
Alan
It's almost certainly possible to do what you want, but it's not clear to me what you mean by "iterations of a function". Do you mean a recursive function? Or an array of functions?
It would be much easier if you could you post a worksheet with an example of what you are trying to do.
Should make this a forum rule. If a question is complicated or worksheet related a worksheet or example should be provided ![]()
Mike
Well, there already is a de fecto rule, because if the question is unclear without an example or related to a worksheet, and no worksheet is provided, we won't be able to answer it ![]()
Good point.
Mike
