Hi. How do I write and describe this summation:
in Mathad Prime 3.0?
P.S. Dont mind the second X in brackets, I can't find a way to describe Xi.
Here you are. As already written you have to use the vector index you get either from the ribbon menu or by typing [
In case you don't know - Mathcad has a lot of built-in statistical functions, standard deviation (you are calculating the square of it) is one of them, so you may use it. See attached sheet.
X should be a data vector consisting of n elements. You have to use the matrix/vector index for Xi (writing X[i), not the literal index you get with Ctrl&-.
You might also consider to sum from 0 to n-1 rather than from 1 to n or change the system variable ORIGIN to 1.
If this doesn't help come back and privide a Mathcad sheet to work on.
I'm really not sure how does data vector work. I've attached what I've came up so far. Could you solve this for me? ![]()
