Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
I do not have upgrade privileges or customer support. Is there a way to update this without costing me more money. I am just a single user for home use.
Apparently the mistake has been corrected on the M030 Build. I am using the M020 Build purchased in 2008. I do know that the numerical integration of this function is correct so I will simply work around this minor annoyance.
>I will simply work around this minor annoyance.<<br> __________________
What annoyance ?
Certainly not the fact that the two algebraic representations aren't same. The form returned by my Mathcad 11.2a is more directly executable and has other numerical advantages. Agreed, the 'p' form is + compact.
On 10/16/2009 12:42:37 PM, jcrow wrote: >I am running version > >Mathcad 14.0 M020 (14.0.2.5 >[802141434]) > > >I do not have upgrade >privileges or customer >support. Is there a way to >update this without costing me >more money.
