Hello!
I am struggling a bit with the symbolic representation of some complex problems. Please, take a look at the attached file.
How can I properly define complex function on form z=r*e^(i*phi)? Should I write z(r,phi)=r*e^(i*phi)? If I do so, then the symbolic evaluation of complex potentials (Phi and Psi) doesn't get along. Also, I am trying to use Re and Im functions to define the real and Imaginary parts of "z" without any success. The same goes to the conjugate of "z": it should be z*=r*e^(-i*phi).
Hopefully somebody can help me out.
UPDATE:
I did some progress, but still can't define properly function "z" without Mathcad telling that some variable is undefined. Updated sheet is attached.
Best regards, Sergey
Defining z as a function with the arguments r and phi would be the preferred way if you want it actually to be seen as a function, but it works both ways.
z as a function:
z as a variable:
z as a function:
z as a variable:
Just an additional note: You don't need to provide a guess value if you evaluate the solve block (find) symbolically.
To the community: Since which version of Prime has it been possible to evaluate solve blocks symbolically again?
This feature of real Mathcad was broken when Prime entered the stage and I wasn't aware that this option had been reintroduced.
I just tried with Prime 6 and it does not work but I never had installed P7 and P8, so all I can say that it works in P9.
Inserting a region with a symbolic evaluation as a line in a program still does not work as it did in Mathcad, though.
What’s New in PTC Mathcad Prime 9.0.0.0
In this document, find topics introducing the enhancements in this release. Enhancements are categorized by functional area.
•Application Enhancements
◦Text Styles
◦Gradient Operator
◦Internal Links
•Symbolic Engine Enhancements
◦Symbolic Solving of ODEs
◦Logarithmic Integral Functions
◦Elliptic Integral Functions
◦Symbolic Solve Block (find)
◦Symbolic Assumption on Function
◦Definite Integral with complex limits
◦Improvement of Calculus Operators
◦General keyword improvements
◦General function improvements
•Numeric Engine Enhancements
◦PDESolve in Solve Block
◦General function enhancements
•Usability Enhancements
◦Custom Color Picker
◦Go-to Page
◦Current Page Tooltip
◦Math region to Text region conversion
Cheers
Ah, thanks! So P9 is the first version where its possible to symbolically evaluate solve blocks.
I tend not to read the "Whats New" document as of the glacier speed of Primes development, but I was aware of the gradient operator and the symbolic solve of ODEs but I missed symbolic solve block evaluation.
Its funny that they really dare to mention the introduction of a custom color picker in the ninth version of a software in 2023.
Nice that we find it out 🙂
Thank you very much for help.
I am in love with Mathcad.
How would you performed the symbolic derivation of the function z? When z is defined as a function of r and phi, the derivative is zero.
The derivative is zero because Phi(z(,r,phi)) simplifies to an expression in r and phi - no z! So the derivative with respect to z is zero.
What you possibly have in mind is easier to accomplish if z is not defined as a function
but it can also be done with z as a function, but a bit awkward as it uses an auxiliary variable (I used z_) and the modifier "substitute":
THank you.
I find the solution given by @ttokoro is most suitable for this case. I will go forward with it.
Anyway, I appreciate the feedback and your solution.
Additional remark:
Depending on your needs, using "substitute" might be something you can use even if z is not defined with respect to r and phi, neither as a variable nor as a function:
