Symbolic solution of first and second order ODE'S
lobe-disabled
I have been looking into using Mathcad to solve 1st and 2nd order ODE'S symbolically.
I know how to solve them numerically.
Is this at al possible in Mathcad.
I have spent some time looking but everything points to numeric solutions only.
Laurence
5 REPLIES 5
Simple answer is "yes".
You should read through the sections on "live
symbolics" (rather than the dead/one-pass menu
symbolics). Live symbolics updates automatically as
new information is provided.
Hint 1. In particular look up the 'un-define' step
where you say x:=x
This recursion 'stops' the symbolic processor (from
using earlier numeric definitions) while the numeric
processor can still give you a numeric answer.
Hint 2. Finally, remember that the equations go red
if the numeric processor cannot calculate. The
symbolic processing can still work properly while
the equation is displayed red 😉
Philip Oakley
Take a look at the Calculus and Differential Equation QuickSheets. You'll see some examples of symbolic differential equation solving.
You also might be interested in the Mathcad 14 E-book,
Inside Mathcad: ODEs and DAEs in Mathcad
posted in the online Mathcad Resource Center.
Thanks to all who replied. I grabbed the Quicksheet.
"I have been looking into using Mathcad to solve 1st and 2nd order ODE'S symbolically".
____________________________
The linear 1rst & 2nd order solvers have been designed and posted many times in this collab, but can't retrace at the moment. As long as the forcing function has a Laplace, then the two solvers works fine. For variables coefficients, you should refer to their formal solution. There is also the Frobenius solver in the collab.
jmG
On 12/28/2009 9:27:56 PM, lobe wrote:
>Hello,
>numerically.
>Mathcad.
>Thanks
>Laurence
________________________________
This is the quick sheet I have designed years ago.
If you have red in your version: incriminate MuPad !
Note q(t) was made a bit more complicated than usual.
Note the Odesolve inaccuracy .
jmG
