Why? Because results for a, b, and c should give:
MC Prime 9 fille attached.
The error message is ridiculous, considering that:
also does not have a finite amount of solutions. As it is, Prime will give:
and you can have:
I'd say, report it as a bug. Especially considering that Mathcad 11 gives:
Well, not every innovation is an improvement! This is especially true for Prime.
Here are the results of Prime 6 with the old muPad engine still available there, compared to your disappointing results with the new FriCas/Axiom symbol kernel.
Of course the "solution" a=any number b=c=0 is wrong, as a,b and c can't be chosen to be zero (same for x2)!
As Luc said - if you feel like doing so and think it may help, you may consider reporting your results to PTC support as a bug in the new symbolic engine.
I found one workaround...
For example, from the first equation we can solve for b:
Then with that b:
And then:
"Of course the "solution" a=any number b=c=0 is wrong, as a,b and c can't be chosen to be zero (same for x2)!"
There is something to say for it: the equations can/could also have been written as:
x2*x1*a*c = b
x3*x1*a*c = c-b
x4*b*(c-b) = x1*a*c
Now if c and b are 0, then a (and x1...x4) can be any number:
But the fact that b and c appear dominantly in the denominator of a division prevents them from being 0.
However, that is still no excuse to flag an error for too many solutions.
Sure!
For a fully correct solution it would be necessary to say that the result is only valid if x1, x2, x3, x3 and x2+x3 are not zero, otherwise there is no solution (given the original equations).
