The variable is undefined. Check that the label is set correctly
BY_9768522
I can not find the result. Example11 is my sheet it should be like in the file example22.
regards,
Can you enclose the worksheet.
Question why use symbolics?
Cheers
Terry
(To:BY_9768522)
Maybe it helps to turn on units/constants in symbolics and let the sheet recalculate.
Otherwise I second what Terry had said - post the worksheets, not just pictures.
