These units are not compatible
OA_10103826
I can't find the problem, everything else has been working except this one for some reason
(To:OA_10103826)
@OA_10103826 wrote:
No, the error is at first a unit mismatch and after you add the units as I already described you get a "no solution found" error. So it looks that both of my guesses from above apply.
So you must add the units and then you have to check your equations because I tried a couple of different angles and none yields a solution!
It looks to me that you are trying to intersect a small circle and a much larger hyperbola which have no common points, so the solve block fails!
7 REPLIES 7
(To:OA_10103826)
You should attach the Prime sheet itself, not just a pdf and a picture.
We don't even see what the error message is.
Best guess is that for one of the angles in the vector Phi the solve block fails to find a solution.
EDIT: I see that you have "hidden" the error message in the topic of the thread - a unit mismatch.
So my next guess is that you have to add units to the zero and also to the 0.2 in "(0 - x.F)" and in "(y.F - 0.2)".
(To:OA_10103826)
It's a stupid exam thing, there can be so many things wrong and its just math there that i need to figure out, change numbers and +/-
So thank you
Welp it fixed that error, but now I get no solution found, but I'm guessing thats on my part, thank you
(To:OA_10103826)
Yes, see my reply above.
It looks that maybe O4f is too small or EF too large, so the circle and the hyperbola don't intersect. The formulas needs some checking.
