Thousands separator
mdkress-disable
Thousands separator
Is there a way to format results to show the comma for the thousands separator. 1,250,000.0 NOT 1250000.0!!
>Is there a way to format results to show the comma for the thousands separator. 1,250,000.0 NOT 1250000.0!!<<br> ________________________
If you type the result as text and select "Courrier New", it will separate and in nice numbers.
jmG
Are you saying that you have to manually type the result in text out? That seems like it defeats the purpose of MathCAD to change results as variables or inputs change.?
According to standards this is not allowed. Only narrow space are allowed to separate certain digits.
Steen Gro�e
