Too many initial conditions error in Mathcad using Odesolve. Need help in order to finish lab. attached is lab.
You have made three errors
Corrected worksheet attached
Sorry, the answer was for noodlepie!
Remaining valid the observations made by Werner and his sheet, I suggest you that you can also use the units of measurement for each constant and variable, with the foresight, however, to make them dimensionless before the solution block, as shown in the photo:
