Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Trig Identities (Help file)
PhilipOakley
In the trig & hyperbolic identities help file, the
final ones for tanh(x) in terms of tan(z) are
incorrect. (on the very last line)
C:\Program Files\Mathcad\Mathcad 14\Resource
Center\en\qsheet\references\calculus\trigident.xmcd
The error is that it changes variable between sides
from 'x' to 'z'.
Also it doesn't actually list the coth identity (it
is mislabelled tanh a second time.
I'm using V14 M030.
Philip Oakley
What is the path (menu selections) to get to that sheet? I can't find it. Might be new in MC14M030 (I'm still using M020).
__________________
� � � � Tom Gutman
PhilipOakley
(To:TomGutman)
Select the insert function button/dialog.
select cosh, and press the "?" help (question mark)
button.
Then on the help page select the quicksheet.
That should take you to the
CALCULUS REFERENCE FORMULAS
reference tables
Trigonometric Identities" worksheet.
scroll to the bottom for the
"Hyperbolic Functions and Trig Relationships"
It's the last line. (before the "*" note about green
annotation brackets)
Philip Oakley
Got it. There is a further bug in that the quicksheet reference index does not list this under the calculus section. Makes it hard to find.
__________________
� � � � Tom Gutman
I logged this.
Mona
