Trying to solve for a variable using iteration and a solve block without previously defining a var.
SS_9985257
 I am trying to solve this equation using iteration and a solve block for Q without previously defining Q as for my application I would not have the value for Q. Am I on the right track here and if not could somebody point out my mistakes? All of my other variables are previously defined and the only thing I don't have defined is Q. I want to be able to spit out a value for Q given all the other variables definitions. Thanks in advance! Below is an attachment of the solve block, I can provide SS for the other variables as needed.
We don't need no stinking solve block!
SS_9985257
(To:SS_9985257)
For refrence, this is my other attempt that I know is in the wrong direction but if it helps anyone:
SS_9985257
(To:SS_9985257)
Third attempt is getting closer to what I want  but unsure if it is exactly what I want...sorry for the spam but this problem is urgent for me.
(To:SS_9985257)
You should attach your worksheet, not just pictures.
And also state which version of Prime you are using.
In your first attempt using a numerical solve block you might have forgotten that you need to define a first guess value for Q.
In the second attempt using the symbolic solve it might be a problem with Primes infamous auto-label feature. Can tell by just seeing the picture, though.
EDIT: Haven't seen Fred's response at first. If Q is not real valued, the solve block does not find an answer if the guess value is real. So you would have to use a guess like Q:=1i
