Unit problem
kenan2
Unit problem
Hello.
I have a problem with the units see .mcdx.
The first one is calculated with units.
The second one is calculted WITHOUT units.
The second one is correct, is it impossible to make the same answer with the first one just with units?
Thx.
ttokoro
(To:kenan2)
(To:kenan2)
This is what the "unit" Delta°C should be used for. Note that difference of temperatures in units other than Kelvin is not done by simply subtracting the values in °C.
Note the difference:
kenan2
(To:Werner_E)
Hmm.. thanks worked with the delta celsius, but do not work with Kelvin ?
LucMeekes
(To:kenan2)
You're you're redefining deltaTlm just before you use it to calculate Q'...
Is that intentional?
(To:kenan2)
Not sure what you mean. Delta °C IS Kelvin
