Good afternoon friends of the forum, I have a question about units,
as it is showing an error and I don't know how to solve it.
Bom dia,
That's simple. The unit Mg isn't defined in Prime. But you can do that yourself. Add:
in your sheet, and the error should be gone.
Be sure to label Mg as a unit (not as a variable).
Boa sorte!
Bom dia,
Boa sorte!
