Units problem
CA_10155699
3-Newcomer
Units problem
i use the same units and still tell me that units are not compatible.
LucMeekes
(To:CA_10155699)
You're adding expressions that can't be added because they have different units.
Prime flags the second part as error, but I think the error may be in the first part.
That's not Newton, whereas:
Most of the other are in N, except:
I guess there are errors in your formula for P. Maybe you need to add the three g-terms instead of multiplying them...?
LucMeekes
(To:CA_10155699)
Yessss, ffs, it was a sum there, not a multiplication.
Thank you very much!!!!
