Iraj
Units
Hi
What is the difference between unit  "ton" and "tonne" ?
LucMeekes
(To:Iraj)
The difference is about 93 kg.
The ton is 1000 lb,
the tonne is 1000 kg.
LucMeekes
(To:Iraj)
The ton is 1000 lb,
BenLoosli
(To:LucMeekes)
Last time I looked, 1 ton = 2000 lbs, which is what your formula shows.
LucMeekes
(To:BenLoosli)
Of course, you're right.
I didn't look carefully enough. Fortunately I added  the Prime expression.
Derbigdog
(To:LucMeekes)
A US ton = 2000 lbs.
