Hello All,
I am generating values for DEFORM FEA software to determine a sinusoidal motion.
My current method is to develop the function for my motion in Mathcad, then take the variable value and transplant it into Excel. From Excel I can copy and paste into my DEFORM table.
I would like grab the values directly from Mathcad.
Any suggestions would be appreciated!
Don
Two things that would at least simplify what you are doing are:
1.) WRITEEXCEL. would dump the data into excel right where you want it
2.) Add an Excel component. Then you could cut/paste easier.
But I don't think you can avoid excel (unless deform accepts txt, csv or prn - which mathcad can also write.
This worked great once I activated the full license.
