Using range values in solve block
vp04v-disabled
Dear all
How to use range values and get the answers in solve block("Given" followed by "find"results)
IN mathcad there is a rule inside solve block we cannot use range values.
Is there any other possiblities to overcome this?
T1/T2=x
(T1-T2)=Po/vel
where x have series of values.....
Thanku
prakash
On 8/7/2009 1:10:35 AM, lmw wrote:
>Dear all
>"find"results)
>use range values.
>Is there any other
>T1/T2=x
>(T1-T2)=Po/vel
>values.....
>Thanku
>prakash
You can/must create one user function. See:
Val
http://twt.mpei.ac.ru/ochkov/v_ochkov.htm
Thank u sir...
Let me try to write function
Prakash
>In Mathcad there is a rule inside solve block we cannot use range values.<<br> _________________________
The other way around: Numerical solvers in Mathcad are "scalar", i.e: taking range variable(s). For discretized variables, the construct is a bit different, mostly via a piece of program. Those things circulate regularly in the collab.
jmG
