Mathcad 15 would give me an indication that I was reusing a variable. Prime 8.0 does not give any indication that the variable is used again. Is there a setting to allow this feature? See attached.
Thank you!
Hi Bob,
check whether the redefinition button is switched ON.
Raiko
Thank You! It works!
