Vectorization
NA_11204287
8-Gravel
Vectorization
Hi all, can anyone teach me how to produce the results based on the if statement as shown in the attached picture? Thank you for your kind help:')
(To:NA_11204287)
Simply add two additional arguments to Luc's function
LucMeekes
(To:NA_11204287)
You have  just one problem: What should be the result if (x/150)=tw... (if they happen to be exactly equal)?
Anyway, here's your function, assuming equality should instruct to use equation 1+1:
Since you didn't attach the worksheet, and didn't state which version of Prime you're using here's an example:
what if the value of 2 and 20 are in equation, not a single digit?
how can we produce a result following the if statement? example as below. btw, i'm using MathCad Prime 10.0.0.0
(To:NA_11204287)
Hi @NA_11204287,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
PTC Community Moderator
PTC
