I used to use full version MATHCAD. By using "Select All" and "Copy Selection", I can copy the data from my mathcad worksheet, and paste it to Excel directly. Recently I am using a trail version in a Windows 8 system. When I tried to do the same thing, by selecting some data and click "Copy selection", it shows a bitmap or some other kind of figure will be pasted to the excel, instead of the data itself. I do not know what happened, and just want to copy the vectors of data. Would anybody know how can I solve this problem? Or is it a restriction of trial version? Thank you!
Welcome to Prime!
Try inserting an EXCEL component and writing the data to the component. Then you should be able to edit the component, select the data, and copy it.
Much, much better, isn't it?
Hi Fred,
It seems like this method cannot work either. See this picture. I was trying to copy the data from f(f1) but it still shows in an imagine format, in the EXCEL component in my Mathcad worksheet.
Maybe the free version won't allow you to cache a worksheet.
What a very appropriate typo when referring to Prime ![]()
I think "trial" is quite good too ... ![]()
Stuart
