Hi all,
There occured a problem in my work and I traced back the error, because of the dependencies it was hard to spot but once done, it seems like a really simple problem but can not explain why. Hopefully experienced users can help me get over this.
Have a nice day
It's not a bug at all. Im(exp(i*x)) is only equal to sin(x) for real x.
You have numbers with large imaginary parts. The sin of such numbers have both real and imaginary parts that are outside the range of the floating point processor. So you get a floating point error.
You can get a result by taking the imaginary part of e^ix, where x is the argument you pass to the sin function. It is zero to within the numerical precision of Mathcad. Don't know why the sin function itself doesn't like it - some peculiarity of its algorithm I guess. See attached.
Alan
Is this a confirmed bug or am I missing something ? There seems to be no reason to get floating point error in this case.
Is it possible for Mathcad to use as many floated decimal as processor can ? Precision will be sacrificed for sure but is it doable ? If it had parallel processing capabilities, this wouldn't be a problem IMHO.
