Hi, does anyone know how to use a root hanning window within the coherence function of the signal processing extension pack ?
I am using Mathcad14.
Peter
You can only use the windows that are offered. To use a different window you would have to write your own version of the coherence function.
Thank you ! Since a root hanning window is not offered I shall write my own version of the function.
