comment extrapoler une courbe
pmat
Avec des valeurs données comment extrapoler une courbe dans le sens décroissant.
Fred_Kohlhepp
23-Emerald I
(To:pmat)
There is an assortment of curve fitting tools.  Attached is a simple example.
RichardJ
(To:pmat)
Do you know what the value of Fi should be at T=0?
Do you know the theoretical function that should describe the data?
(To:pmat)
Where does the data stem from and why do you need that extrapolation?
The Fi data is equally spaced, so it may make more sense to plot T over Fi.
Any reason you have used a logarithmic scale on Fi?
WE
pmat
(To:pmat)
merci; ça m'a beaucoup aidé.
