complex
XDN
complex
Hi community
I calculate a matrix of numbers,sometimes in the matrix there are complexes.
how can i find them, because my matrix have lot of line.
(To:XDN)
@XDN wrote:
Hi community
I guess that with "complexes" you mean non-real number. After all 5 is a real number and as such its a complex number, too 😉
Not sure what exactly you have in mind if you write the you want to "find" those non-real numbers.
Here are a few suggestions - hope it helps:
Remarks:
"match" will fail if no non-real number is included in the vector
"trim" will fail if all vector elements are non-real
A workaround is to create modified "match" and "trim" functions:
Note: In Prime use "else" instead of "otherwise" and "try" instead of "on error"
7 REPLIES 7
(To:XDN)
@XDN wrote:
Hi community
Remarks:
XDN
(To:Werner_E)
Yes ,that's exactly it
Danke
in robotic applications, the complexes show a tilting of the geometry with respect to the referential. With your solution, I know the robot positions which are out of the frame
XDN
(To:XDN)
In P7 where i find "Im"?
I don't uderstand this "IM" it is a MC15 function?
(To:XDN)
"Im" (lower case "m"!) is a normal function also available in Prime 7 which returns the imaginary part of its argument.
Im(2-3j) -> -3 and Im(123) -> 0
So asking for Im(...) not being zero means asking for a non-real number.
The pendent to "Im" is the "Re" function which returns the real part of its argument.
I assume you are using the full version of Prime 7 and not the limited free Express version and so "Im" should be readily available. Maybe you typed an uppercase "M" instead of a lowercase one? Names (functions, variables, units) are case sensitive!
In case you are using the Express version - "Re" and "Im" are functions which are not available in Prime Express but can easily be defined using the (available) conjugate complex operator:
XDN
(To:Werner_E)
well it seems that this function is disapear in P7 ...
P7 return "error" and i don't find this function in P7 help
(To:XDN)
Looks like you are doing something wrong.
I don't have P7 installed but I sure can find the function in the P7 help.
See here: https://support.ptc.com/help/mathcad/r7.0/en/#page/PTC_Mathcad_Help%2Fcomplex_number_functions.html%23wwID0EG5UEB
XDN
(To:Werner_E)
I didn't find it, I'm an idiot
Thanks again Werner
