Does anyone know how to get Mathcad Prime 6 to return the Date and Time?
(I know about the time(z) function, its not what I'm looking for. I want to create a 'timestamp' that I can export into Excel with the associated calculation results)
You can (have to) convert the result of the time() function to the format you desire.
There is no built in function for that.
NOTE that MsExcel (probably depending on version) does NOT have a single date system.
What might help is if you take the following transformation:
This adds the number of seconds between 1900-1-1 and 1970-1-1 to the output of time() and divides by the number of seconds in a day. That number can be transferred to excel and when the cell is properly formatted it will show you the (UTC I guess) date and time. Unless you're using a worksheet with 1904 date system.
Conversion to Primes 9.0.0.0 seems to be pretty ok.
Thanks!
Hi
Here is some Mathcad 15 time functions.
Perhaps someone can transcribe to Prime
Cheers
Terry
I'll immediately admit I'm blind, but, I fail to see any of these functions using the output of the time() function...
How about
